General Tech Start Up after Rebuild
KVH
Sorry, old topic again. But--why do folks say to prime the oil pump using the shaft before installing the distributor when you can do the same thing by cranking the engine with the distributor installed but the ignition disconnected?
If you have installed a new camshaft and lifters its preferable that the engine fire quickly and run at 2,000 rpm to break the lifters in for at least 20 minutes . Excessive cranking is feared to be too hard on the lifters and lobes.
Hi,
I always prime the engine on the engine stand. Its a lot easier to fix a problem that way. I spin the oil pump with a drill and turn the engine over with a wrench until I have a steady oil pressure reading.
Roy
It can take a while for pressure to build, I have done a few and never had a problem until I redid my TR250, which I cranked quite a bit but no pressure. The fear of course is some bearing somewhere does not have any lube, and isn't going to get any until the pump starts . If you can turn the pump without turning the motor you alleviate this concern by building up pressure and distributing lubricant before the motor starts spinning.
