stanchion repair , can it be done?
timbn2
i need to get this bee out of my bonnett! I seem to be fixated on my windscreen and its way to early in the resto for that, so lets get me re-oriented.
if part of a stanchion is broke or a threaded stud is missing/broke can these things be repaired. It looks cast to me so i kinda dont think there is a "filler" to use and then rechrome, but i could be wrong.
So can these be repaired, and what would the process be?
Thanks
tim
Yes Tim, They can be repaired by a specialist,However, the cost will most likely significantly exceed that of a good used replacement or new if available, where the damage is extensive.---Keoke- /ubbthreads/images/graemlins/hammer.gif
The USAF welds alum engine blocks so I guess all things are possible.
Jack, welding Aluminum heads and blocks is old hat now.Welding up the old cast Iron ones properly needs a real specialist.---Keoke- /ubbthreads/images/graemlins/yesnod.gif
Timbn2: I am not dead sure but I believe they are Aluminum.---Keoke-??
That was the point Keoke. Almost anything can be welded today with great results. Make sure the welder is certified.
[ QUOTE ]
[/ QUOTE ]
A well equipped specialist; controlled pre & post heating cast iron is a must to avoid cracking.
Assuming we're talking about a windshield post, I'd think that could be repaired without too much trouble.
Now, I have some old Go-Kart magnesium wheels that I want to repair, and I will give it a go as soon as I talk myself into paying the HIGH price for magnesium filler rod (probably cost me $300-$400 for a couple pounds of rod).
Replace. Watch ebay. Ask Bill Bolton ot John Wilson both from the Oregon club.
