Nelson
I have put several hundred miles on my car since I installed a disc brake conversion. When I apply the brakes and have almost stopped they squeal loudly. I understand that they apparently are not bedded in properly. I have tried to bed them in by driving to 40 mph or so and then hitting the brakes relatively hard until the car almost stops and then acclerating back up to speed and repeating the process. I did this maybe ten times and then when I slowed to get back into my driveway there was the usual high pitched squeal. Do I need to really lay hard on the brakes from a higher speed or is there a better technique?
