The engine sounds nice and idles low which is nice. I am not sure what an engine bearing does when the bearing SPINS. Maybe those little tabs on shell go flat. To me the engine sounds nice and I do not know if a spun bearing would make a difference, but surly not a good thing
The noise sounds to me like a TB rubbing.
Does your slave cylinder have a return spring on it? If the spring is one of those strong springs, I would test the car without it, and perhaps “hillbilly up” some softer spring just for the test. I cannot justify completely why I think it might be the spring, but I have seen those strong wrong spring cause problems usually with clutch engagement. Anyways you said the clutch works fine; I guess I am thinking the TB is hitting on an uneven different plane that is not parallel. So pretty crazy huh?
steve
steve
