Ariddick
Member
Need some troubleshooting here. Having a hard time fixing/locating this loud sqeak.
I rebuilt a TR4 gearbox and replaced my stock TR3 gearbox.
Runs great, but about 2 weeks later, I consistently get a loud squeak about 10 minutes into a drive.
Since it is consistently after 10+ minutes, I assume it is due to heat.
While idling and in neutral, the noise is present at higher RPMs (1200+) or when I am pressing on the clutch.
Noise gets louder when pressing on clutch.
I assumed throw out bearing and replaced with new bearing, but noise is still there
Third pull of the trans and I have now replaced the throw out bearing carrier, pilot bushing, and swapped out the fork.
I rotated the pins on the fork also so there is little play.
I also flipped how I mounted the bell housing dust cover as I’ve read those sometimes rub on the flywheel.
Noise still present and behaves exactly the same way.
Could it be the pressure plate on the clutch?
1959 TR3A
1959 TR3A
Hi Guest!
