philknight
My 73 TR6 engine loses power and then stalls after warming up and running a few miles. If I let it cool down a bit it will start and run well until it warms up again. Thought it might be a problem with the optical electronic ignition installed by the dpo and in removing that realized that the wiring in the car had been hacked up so much that replacement was required.
This is what I've done/installed so far.
new main harness from British Auto Wire
Petronox ignition
New spark plug wires
new sport coil
rebuilt original fuel pump
new fuel filter
blew out fuel lines from the fuel pump to the carbs
adjusted floats
replaced float valves
replaced diaphrams
replaced vacuum lines
installed heat shield
timed at 4 deg atc
then timed at 4 deg btc
Everything seems perfect until I'm about 10 miles from home and then it sputters and dies. It's fun to limp home a half mile at a time. Any Ideas?
Petronox ignition
new sport coil
new fuel filter
adjusted floats
replaced diaphrams
timed at 4 deg atc
