Greetings from Montana--I am in the process of replacing my third release bearing in a 65 sprite. First one (VB) lasted 150 miles. Second one (VB) lasted 250 miles. This one is from B-Hive and I hope to have better luck. My question is: The surface on the pressure plate that the bearing contacts is somewhat rough--could this take out two bearings that fast or should I look at other things? The pressure plate was new on the first time around so that was'nt the problem. Any help would be greatly appreciated. Thanks JSM
