I had to trash the two flat u bolts that go around the spring. They are not available from Moss or VB. Anyone ever have to replace these and what did you use?
Tony, Jack is referring to the clamps that go around the spring stack. Flat pieces bent into a square "C" shape, with a horizontal bolt through the bottom.
Jeff.
Thought you wanted the 265-570. When I had my springs rebuilt years ago they replaced the other U bolts with band straps, I would think that a spring shop would have those.
Jack,
Let me know how you make out sourcing the clamps; I have an extra set of 1/4 elliptic springs that I can steal some parts off of if you want to stay close to original. A spring shop should be able to supply a modern equivalent though as GB1 pointed out.
