Guys. you've given me lots to think about. Been gone for 3 days on vacation.
1)Radial Tires 155R13 / 78 They are now 6 years old approximately. Gee have I had Bugsy that long? Tempus Fugit
2) Front end was refreshed with new ball joints, shocks, rack replaced, pinion gear on rack replaced, left and right A Arms etc., swapped out for a set in better shape.
Bugsy was in some sort of accident that tweaked the LF Fender enough to need replaced and even bent the inner fender slightly. That much I know. Front end was in such bad shape that he would change lanes all by himself when hotting as much as a tar strip. Upon reassembly, all parts bolted up easily, nothing needed to be foreces to go back together, hence feeling that minor sheet metal damage in fender bender accident nothing to frame and front suspension in the way of damage.
Now RF hit a bump, no noise, no clatterm, no bump steer. LF hit a manhole cover, slight bump, a definite slight noise of some sort and some small amount of bump steer. Definitely a difference in the two sides. My thought after doing lots of cogitation is that LF definitely needs to be rebuilt. I swapped out front suspension from another Spridget and it was far better than what was on hte car but it definitely still needs some work. Since replacing the suspension components there probably has been 7-10k miles put on the car. All has stayed well lubed but still wear and tear on a front end on unknown mileage to begin with.
