Jim_Gruber
Question, are solenoids available from the normal parts houses or do I need to go to VB or MOSS for one? Bugsy my '68 Sprite, for the third time gave me the single quiet click scenario yesterday and I needed to push start him at
the gas station. Interesting 4 guys saw me start to push him, stopped what they were doing pumping gas and rushed over to help push Bugsy, all without asking or exchanging a single word. A 10' push, popped into first and off I went. I waved thanks and went home. Rolled into garage,
turned key, and Bugsy started right out without any hesitation.
Now this is the 3rd time this has happened. I'm not getting the solenoid stutter as in not enough juice in the battery just a single click and nothing. Tried restarting 5-6 times same results single quiet click and nothing. I need to get in there and clean everything and check connections. This could be bad switch contacts at key switch, bad solenoid,
bad starter( not getting the click, click, click thing like low voltage from battery), battery that is now 6 years old, generator not putting out enough juice to pull down the relay, generator has been doing a little bit of major hi charge whine lately so possibly battery now 6 y.o.
might be suspect. Need to dig in and do some testing..
I know someone on this list or one of the other lists had a similiar problem and changing the solenoid resolved all issues.
