Whitephrog
Are there any law about Spridget cruelty similar to those for animal cruelty?
https://tinyurl.com/da8pwk
Pythias said:the Hog's Head is the Diffy... doncha speek Southern'?
I tried midget rearend once and learned that lesson as well :wink:histerical said:" Then again, I don't call the transmission a "tranny" after I googled that once by mistake! Ugggg! "
I had to try this myself. Sorry I did.....
Nah, its got to be the whole piece to be legal. Not supposed to remove vin plates. That cowling is the main part of the car with the vin attached. Its what makes the car, you can replace everything else but that and it is still that car.jlaird said:Kim, I have a data plate. Nothing else if it will help.
regularman said:Nah, its got to be the whole piece to be legal. Not supposed to remove vin plates. That cowling is the main part of the car with the vin attached. Its what makes the car, you can replace everything else but that and it is still that car.jlaird said:Kim, I have a data plate. Nothing else if it will help.
No, you are supposed to leave the area around the Vin untouched. If you were to replace the cowling with a new one, you have to get the DMV guy out to put the vin on the new one with his special rivets. Again, I just need a junker with a title and that vin and all still attached to the cowling so I can make two from one. Its a darn shame there is not a good way to get a title from a junked vehicle but its not worth all the trouble and expense of all that. I guess its for a reason but it sucks.BugEyeBear said:regularman said:Nah, its got to be the whole piece to be legal. Not supposed to remove vin plates. That cowling is the main part of the car with the vin attached. Its what makes the car, you can replace everything else but that and it is still that car.jlaird said:Kim, I have a data plate. Nothing else if it will help.
SO, IF you somehow damage just the cowling BUT the rest of the car is intact, and then you replace just the cowling with a newly manufactured piece, what would it be then?
IMHO if you cobble together a car from 2 donor cars, I would have to say that you could use the VIN from either donor (preferably the one WITH a clear title). This might not agree with "the letter of the law" but as long as you legally acquired both cars what harm is being done? After all, you COULD always stamp matching ID numbers anywhere on the body that you desire (yes, I've seen it done...), thereby satisfying even the most diligent inspector!
I'd have NO PROBLEM sleeping at night, & I'd DEFY the DMV guys to determine that the car is not legal!
Besides... Don't most FULL Restorations involve removing the VIN Plate so that you can paint underneath??
regularman said:No, you are supposed to leave the area around the Vin untouched. If you were to replace the cowling with a new one, you have to get the DMV guy out to put the vin on the new one with his special rivets. Again, I just need a junker with a title and that vin and all still attached to the cowling so I can make two from one. Its a darn shame there is not a good way to get a title from a junked vehicle but its not worth all the trouble and expense of all that. I guess its for a reason but it sucks. It is a felony to posses a vin from a car or the special rivets and in this state any vehicle with a vin removed is to be crushed by law.BugEyeBear said:regularman said:Nah, its got to be the whole piece to be legal. Not supposed to remove vin plates. That cowling is the main part of the car with the vin attached. Its what makes the car, you can replace everything else but that and it is still that car.jlaird said:Kim, I have a data plate. Nothing else if it will help.
Not really just one that is pre 1974 so It will be over 35 years old and not require inspection in this state. I would kind of like a sprite title so I could do up the Austin thing a bit, but this one is going to be much less original than my 71. Its going to be my experimental vehicle, I am not sure what will power it right now but it will not be the a series and probably not gasoline either. Just a play toy but I don't want to start on something that I don't have the proper paperwork for.BugEyeBear said:Hi Kim,
<span style="font-weight: bold">WOW, those NC DMV guys sound REALLY strict, & tough!
Too bad, as you're not trying to do anything illegal or dishonest, you're just trying to restore an old car!</span> (They don't make it easy on us, do they...)
I've never looked that close, but isn't a Spridget VIN plate just held on with regular rivets? I've never noticed that they were anything special. I really can't imagine that it would be difficult to find rivets of similar type, shape, size...
Many years ago, I had an early 70's Datsun 510 that had some surface rust under & around the VIN plate. When this area was repaired/repainted we simply drilled out the rivets, did the repair, and then reriveted the plate back in place. Looked exactly like it did when it left the factory. Never had anyone question it.
Also, it is pretty common for the VIN or ID plate to be removed from a car before it gets media blasted, as the blasting can destroy these plates (or at least make them unreadable). I'd guess that most of these plates are reinstalled w/o DMV supervision.
<span style="font-weight: bold">I DO appreciate your desire to adhere to the letter of the law, and maybe this is advisable in NC as it sounds like the NC DMV guys are a rough bunch.</span>
I'd be willing to bet that SOMEONE in this forum has a junker w a valid title that they want to get rid of. Have you posted a thread to inquire? Is there a specific year or Mark that you are looking for?
-Bear-![]()
