Deleted member 21150
I'm looking to convert my bolt on wheel hubs (ford rear) to splined hubs. Are there any advantages or disadvantages between coars and fine threads for the knock off?
Hi Guest!
That happened to the Works Rally cars, not in normal driving....
I'm not aware of splined adapters cracking/breaking because of a too thin cross-section, only of the splines themselves wearing down, so the increased thickness__required for the coarse threads__seems unwarranted. But I've been wrong before...
I must've missed the memoThat happened to the Works Rally cars, not in normal driving.
Not necessary.I'm getting close to finally getting all of my parts to convert to splined hubs. Now my question is about the shims and spacers. The bolt on hubs that were on the car had neither? Are they necessary? They just had the washer and nut, like an American car.
Not necessary.
John - if you're referring to the distance piece and shims on the front axles, that's a controversial statement. Many would disagree.
And, I'll fall back on the old saw: do you think the bean counters at BMC would have allowed the extra few quid to be spent on the spacers and shims if they weren't absolutely necessary?
I was thinking (I know - dangerous) based on the original post, we were talking about the rear axle.John - if you're referring to the distance piece and shims on the front axles, that's a controversial statement. Many would disagree.
