Alabama_Hokies
Need some Stromberg help. At least I think it is a carb problem.
My 76 Spitfire was running quite well. Idle was solid and no smoke.
The gas tank is in bad shape (internal rust). I have been putting a couple of gallons at a time while working on it.
I added two new filters and filled it up. Ran smooth for about 40 miles. Since then the fuel pump went
out and now it is running very rich and there is black smoke.
Replaced the fuel pump, checked the needle, the diaphragm, the floats, the valve adjustment the compression, still runs rich.
Don't know what else to check, any ideas? I would like to figure this out before removing and sealing the tank.
Thanks,
Dave B
Thanks,
Dave B
