Spit_Newbie
Hello all, Im having a hard time figuring out my very hot running Spitfire. Its running at about 240. Any suggestions? Ive been told they dont usually run hot. Help!!!! Spit Newbie
Hi Guest!
Likely as not, your car will have only a brass hex-head plug in the block drain. It can be found on the RH side of the engine, towards the rear, maybe half-way down the block.Spit_Newbie said:... I dont have an actual petcock on the block. Which side of the block is the plug on? I would like to try to flush from that point too....
Amen to that! Many a "good" radiator in a hot running core has a lot of lose and missing fins.TR3driver said:/bcforum/images/%%GRAEMLIN_URL%%/iagree.gif Ask them about thermal efficiency while they have it. I fought overheating problems on my TR3A for a long time until I did that. They said the fins were no longer in good thermal contact with the tubes, so the radiator wasn't removing much heat even though the water flowed fine. After they recored it, all my overheating problems vanished.
