Spitfire Spitfire rear suspension
gugma1997
Another question if I may please: When I jack the rear of my '72 Spitfire up, the rear wheels hang bottom inwards (like a VW bug does when jacked up) and when down on the ground, they (especially the drivers side) are just the opposite with the bottom of the tire out making the tire lean. Again everybody, I am new here and I hope I explained it so you can understand. Thank you!
Welcome.
The condition you describe is normal.
Spitfires have a form of independent rear suspension called "swing axles" (just like VW bugs). When the car is jacked up, the wheels will have "positive camber". When the car is on the ground, the wheels usually have a little bit of "negative camber". If your car has the original rear spring, it made be somewhat weak, allowing the car to have a bit too much negative camber. By the way, Spitfires have a single transverse leaf-spring in the rear. A weak spring on a Spit is not ususual and it's not a problem that I would fix right away (unless you see excessively loose parts in the rear suspension or the car is bottoming out all the time).
While you're looking, you may also want to check for any excess rust where the spring is mounted to the frame.
Hello and thanks! I just wanted to make sure that it wasn't a big problem as I have more pressing things to get fixed on this car. I will check on that rust issue.
