frankenstang57
OK, all has been going well on the Junkpile Spitfire, soon to be known as what else? Frankenspit! Anywhoo, I've been doing battle to remove a rear hub from the axle.(yes, the first of two...) I want to re-pack the rear bearings and replace the seals. Since all the grease encountered on this car seemed to resemble paste, and probably has the same lubricating properties, I thought it would be wise to replace it. First pull, 3 jaw gear puller. Nope. Second shot, garden variety parts store steering wheel/gear puller. The peace sign looking thing. I popped out two of the studs and installed two 3/8" grade 8 bolts. This pull bent the puller into an upside down "U". It also started to bend the hub. Pull 3, installed new HF HD gear puller. Heated the hub up until it was glowing, gave it a pull. #$%$^&%$'d up the bolt on the soon to be returned puller and moved the hub about 1/16". Am I missing something here? As far as cars go, I have the patience level of a saint. This "part" is heading down the road to DEFCON 1 pretty quickly. Any suggestions?
Hi Guest!
