Spitfire Spitfire rear end noise
eejay56
My 78 Spit has developed a noise in the rear end. It's kind of a tunka-tunka sound coincident with wheel speed. Maybe louder on left turns. I've pulled the brake drums and all looks OK. I put the car up on jack stands and ran it, no noise. It almost sounds like the axle is banging on something. What should I check?
Andrew Mace
Check the u-joints...NOW! "Louder on left turns" tells me that the extra strain of that movement causes the bad joint to make noise.
Do NOT wait.
Repeat....
Do NOT wait. Check and replace NOW. You do NOT want one of these to let loose on you (don't ask me how I know).
BTW, there are other possible causes for the noise, but a u-joint is by far the likely candidate!
myspitfire
Like Andy said DON'T WAIT!AND TO ADD;>>>My Spit did the same thing at one time KLUNK KLUNK,Until i found the RIGHT REAR AXEL SHAFT BEARING & CAGE HAD DISINTIGRATED.So i went the common sense route & entirely replaced the whole right rear axel assembly including the axel,bearings,ALL THE u-joints,& while at the same time i replaced the leaf spring.NO MORE NOISE & NOW more piece of mind.I can even hear gas sloushing in the gas tank now at 30mph.OH!ONE OTHER THING while your at it RE-TORQUE ALL the flange nuts on the drive shaft front & back they have a tendency to work loose.Buy HIGH QUALITY U-JOINT's some u-joints are made in India or China which are junk.British are the best(MOSS,or TRF,or Rimmer Bros.
Ken......& WhiteLightning...1500 Spitfire
eejay56
eejay56
How do I check? The u-joints were replaced Aug of last year (before I bought the car). The shop that did the work is in Portland so I'd like to know they are bad before I drive up there.
Andrew Mace
eejay56 said:
How do I check?
Here's some very useful information on the noises, causes, checking for problems, etc. It is possible that the u-joints themselves are still ok, but oversized circlips are required to set them "tighter" as per the information in that link.
cutlass29
- sounds like uj's...I had the same thing end of last summer...that's why my rear axles are in pieces now being re-built. Mine was more of a pronounced squeak/squeak but definitely the same rhythmic noise especially on cornering. Tough, if not impossible to test on the car. Suggest you disconnect half shaft from differential mounting plate and check uj that way....4 bolts to undo but mark both flanges before removing so you get them back the same way.
guzzul
I would first visually inspect the joints. If one of the retaining snap-rings has popped out it won't be long before the u-joint end-cap will follow it. Check both yokes on each axle carefully for any movement of those rings.
Get a couple of screwdrivers or something into the axle yokes and try to see if there is ANY movement bewteen the joint and either flange. There should be none.
You will probably not be able to detect lateral movement of the joint (that is, sliding up and back and banging against the retaining ring) by moving it with your hands. You could give it a try by moving the joint laterally in each yoke.
If in doubt at all, get it into a garage for a pro to have a look at.
If you hear the 'tuka-tuka-tuka' more on deceleration than acceleration, it is very likely a u-joint. As Andrew says, you do NOT want to lose one of these at speed.
Don't forget to check the prop-shaft u-joint also.
TheAssociate
The u-joints can be tricky to install. All the u-joints I have replaced had previously been installed wrong and had pins lodged in the bearing cap. If you've got a distinct "clackity-clack" that goes up and down with speed it's your u-joints. Doesn't matter when they were replaced.
Adam.
____________________________________________________________
1973 Triumph Spitfire.
R Spitfire Spitfire rear end noise from heck Triumph 14
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
J Spitfire Spitfire Rear Brake Bleeding Triumph 9
B Spitfire Torque specs on rear spring bolt, Spitfire Mk3 Triumph 2
T Spitfire 1979 Triumph Spitfire 1500 rear wheel alignment Triumph 4
spitfun Wanted:Triumph Spitfire race rear spring Racing 2
T Spitfire Spitfire differential rear bushings Triumph 5
R Spitfire Spitfire - Rear Hub disassembly help! Triumph 2
jollyroger Spitfire rear window seal 76 spitfire Triumph 3
dklawson Spitfire Spitfire Rear Wheel Flanges-Common Problem or DPO? Triumph 7
S Spitfire spitfire rear brakes Triumph 5
J Spitfire Spitfire Rear Suspension Triumph 8
frankenstang57 Spitfire Spitfire rear suspension problem Triumph 15
D Spitfire spitfire rear spring question Triumph 2
D Spitfire spitfire diff and rear spring Triumph 9
W Spitfire Rear Suspension Sway Bar?? on 1980 Spitfire Triumph 5
D Spitfire 1976 spitfire rear bumper question Triumph 3
JBann Spitfire Rear passenger brake drum smoking - Mk1 Spitfire Triumph 4
eschneider Spitfire Watchpoint - spitfire rear trunnion bushes Triumph 4
eschneider Spitfire Spitfire torque specs - rear upright / trunnion ? Triumph 4
eschneider Spitfire another Spitfire question - stuck rear hubs Triumph 26
pjsmetana Spitfire Rear Diff, Spitfire Questions Triumph 16
dklawson Spitfire Spitfire - Rear Hub Bearing & Axle Assembly Steps? Triumph 17
B Spitfire odd noise from Spitfire rear Triumph 5
dklawson Spitfire Spitfire MkIV - Rear Hub Questions Triumph 4
D Spitfire 1971 Spitfire rear axle - Help! Triumph 3
tr7andtvr Spitfire Spitfire rear suspension part needed??? Triumph 3
D Spitfire Spitfire rear wheel pulling Triumph 6
R Spitfire '75 Spitfire rear fender top trim Triumph 0
dklawson Spitfire Spitfire - Rear Track Width Identification Help Triumph 2
S Spitfire Rear engine mounts - Spitfire Triumph 2
M Spitfire Rear Tires Leaning Out Restoration & Tools 5
B Spitfire Spitfire-rear suspension question Triumph 14
TR_JOE250 Spitfire Spitfire rear suspention problem Triumph 8
cutlass29 Spitfire spitfire rear trunnion bushes Triumph 4
cutlass29 Spitfire spitfire rear hub seals Triumph 6
frankenstang57 Spitfire Spitfire rear hub removal? Triumph 11
middleagecrazy Spitfire 76 Spitfire rear axle bearings Triumph 5
C Spitfire SPITFIRE REAR BRAKES Triumph 5
guzzul Spitfire Spitfire rear hubs - where to position bearing? Triumph 6
cutlass29 Spitfire spitfire mk3 rear engine oil seal Triumph 1
Simon TR4a Spitfire Spitfire rear spring Triumph 1
G Spitfire Spitfire rear suspension Triumph 2
B Spitfire Spitfire Mk3 Rear Wheel FREE CAMBER VALUE Triumph 4
B Spitfire Spitfire Mk1 Rear Anti Roll Bar / Sway Bar Triumph 3
B Spitfire Spitfire Mk1 Rear Spring Shape Triumph 7
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
