dklawson
Our project MkIV Spitfire came with an unmounted, used, OEM front spoiler. It clearly was mounted at one time as there are extra mounting holes in it that line up with holes in our car's valence corners.
I'd like to clean up spoiler and install it. However, when lifting the spoiler up to the car body, it seems to interfere with the filler panel that goes between the valence corners. When the spoiler is installed is that filler panel removed? If the filler panel is left in place, is the spoiler supposed to push against the filler panel? Lastly, there appear to be two captive nuts molded into the back of the spoiler. If those bolt holes are used, what do they line up with?
Hi Guest!
