Trevor Triumph
The Herald is on the road, sort of. I can't have the front end aligned because the balls joints and tie rod ends need to be replaced. The tie rod ends are the same part number, for the Herald and the Spitfire. The upper ball joint have the same part number. The problem is the trunnions are different parts numbers but attach to the same vertical link. The question: "Can I use the Spitfire parts on the Herald?" TRF is having a sale so I could rebuild the front end and steering at reduced price. And have the parts a little quicker than ordering from the UK.
T. T.
T. T.
Hi Guest!
