I am in the process of rebuilding a 1966 Mk 2 Spitfire and need some feedback. I have the half shafts and trunions on my work bench. To rebuild them the manual says I should remove the outer hub and then pull the half shaft. The hub is a bear to get off. Now my question, should I pull the hub off as the manual states, or can I just pull the hub and half shaft out through the trunion, replace the bearings, and then refit? What do you think?
So either buy a proper puller from someone such as
