jdubois said:Ok, dumb question of the day. Can I hope to get this throw-out bearing off it's spindle and the new one on by myself, or am I headed back down to the machine shop again?
Should be easy as pie.
billspit said:Should be easy as pie.
The negative ground (black) lead? Or are you positive ground?jdubois said:Oh, and I've forgotten where the plus lead from the battery hooks into the car. I thought it bolted to the bellhousing, but I ran out of holes (i.e. I had enough bolts in the "bellhousing" hardware bag to fill all the bolt holes) so I don't remember where the bolt at the end of the lead is supposed to go.
guzzul said:Hate to make you paranoid, but hopefully the bolt you're holding isn't one from inside that holds the bell housing to the gearbox.
tdskip said:What is that red thing blocking the view? ;-)
