Spitfire Spitfire Fuel Filter
Hi Bob.
Thanks for the reply. I've changed all the lines fwd of the steel lines. I plan to change all the aft lines this winter.
Another shot in the dark. If you have an old fashioned timing light, not an inductive type, the kind that runs inline between the spark plug and the distributor. Try running the revs up (under load) while watching the light. If the light flickers or seems to "miss a beat" now and then your problem is likely somewhere in the ignition circuit rather than the fuel delivery system.
