Spitfire Spitfire Frame chart on ebay, worth it?
Dana_Duncan
Dana, I'm doing a 60 TR3A and there is an absoultly wonderful frame chart in the factory shop manual. I kind of suspect that there may be one in the Spit factory manual. Someone on here will confirm or deny that, I suspect. If you don't have a shop manual better to invest your money in one than in a seperate frame chart. Course I may be wrong, have been before and have the divorce papers to prove it.
Good luck, Tinkerman
I f there is one and the manual is on software, then just copy it go to Kinkos and have them blow it up and have them laminate it.Pert near 36X24 that way.
Thanks Tinker and Don,
I wonder if someone has an electronic copy of the manual and could just email the page?
Thanks, Dana
Get the Bentley! It has detailed frame alignment measurements and checking procedure. And everything else you might want to know.
Good deal. I knew someone would step forward. Copy it on to disk,take it to Kinkos and have them blow it up and laminate it. Put it on youe wall and your golden
Like this
