Spitfire SPITFIRE ENGINES
sabot
Hi all, first time post. just want to make sure.
I should have no problem dropping a 77 spitfire engine into
a 73 spit? Right?
The only problem I see right know is if the wife opens the
garage door and see's 4 spitfires out there instead of the normal 3.
thanks tom
waltesefalcon
You should have absolutely no problem making the swap. I have a Mk II spit that the last owner put a 1500 in it. Speaking of which do you have the 1296 for the MkIV? And if so would you consider selling it?
Cain
[ QUOTE ]
thanks tom
[/ QUOTE ]
Tom,
I suggest installing large mirrors on each garage wall to make it look like an optical illusion that four spits are sitting there.
Regards,
rulle7
Mirrors on each wall would make for an infinite number of spits...or an infinite number of reasons for a divorce, as it were. /ubbthreads/images/graemlins/eek.gif
trrdster2000
Sabot, you will encounter a problem or two if you are using your old transmission and got new clutch parts for the new engine, I think the disk will have to be the old type, other than that everything else works. I have been wrong before so check that the new and old have the same number of teeth. Wayne
waltesefalcon
William,
Destroy the evidence before she can see find it.
Trevor Triumph
Later engine to earlier car... The fly wheel and clutch assemblies are different. The '77, I believe, is a single rail transmission, the '73 a three rail transmission. My wife's '74 engine was connected to a three rail transmission. You'll need the the early fly wheel and clutch assembly. The bolts that hold the flywheel to the crankshaft are different and the clutch plate is a different size, and uses different size bolts. As far as engine mounts and connecting to the bell housing there is no problem. The pre '75 shaft from the transmission is a ten spline shaft, the late single rail transmission shaft is a twenty spline shaft. I had to remember that you are doing the opposite of my operation. I hope I haven't muddied the issue. Call Nigel at Spit Bits, I'll bet he can help. T.T.
S
sabot
hi all, thanks for the replys. i goofed and should have said
the 77 spit drive train, into a 73 spit. my 77 spit is being used as a parts car.
S
sabot
as far as i know it is the original engine in the 69spit. the car was in the process of being dismantled when i got it. so would that be the correct size moter for you? sorry,don't have my notes in front of me about the car. i have thought about trading or selling the car. but thats about it for know. m1sabot
can send more info if wanted.
MDCanaday
Sabot, dont just throw it straight in, take the oppertunity to freshen up the low end, since this is the achillies heal of the 1500. Unless you know this motor rather well infact, I would strip it down and give it a good looking at. Piston wear on a 1500 can become a problem even at 50k due to the extreemly short skirts.
MD(mad dog)
waltesefalcon
Sabot,
I am actually rather interested in aquiring another engine for my MkII spit. I know the 1296 isn't any more kosher than the 1500 thats in it, but for me it would be preferable. Any info you have on the engine and if you will sell it would certainly intrest me.
S
sabot
hi walter, i think i'm not getting the hang of this darn
tread stuff and replying stuff, i don't even know if you will see this. if things work out in the next two weeks i should be unloading the 69 spit. i'll try and check out the engine. what kind of info on the moter are you looking for?
took care of the problem of 3 cars becoming 4.
i turned 3 of then sideways and slid them in close to one another, and then put up my paint booth curtain. now if i can just keep the kids out of the garage. /ubbthreads/images/graemlins/patriot.gif
waltesefalcon
I am looking for either an 1147cc engine or a 1296 cc engine to replace the 1493cc that the last owner put into my MkII. I would rather have one that is a little bit stouter than the 1500s lower end. Also I'd like to be able to drive the MkII as it is now, while I build a new engine for it to minimize the down time for it. If you are going to be selling your 69 whole I won't be interested, I am in enough trouble as it is with two spitfires, but if you are parting it then I'll be interested.
S Spitfire Spitfire 1296 engines Triumph 1
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K TR2/3/3A Mystery Clutch MC? Spitfire....TR4....69-70 TR6??? Triumph 2
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
T Spitfire Spitfire lights Triumph 7
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
glemon Spitfire Spitfire Questions Triumph 7
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
T General Tech Spitfire overdrive, the sequel Triumph 3
