Got the engine and trans out, took the drive line out and am going to have u-joints replaced and have it balanced.
Does anyone know what Canelys means when they state:
Propshaft Problems
I've got this sort of vibration that comes in at 55mph...
(My problem exactly)
They can make all the difference between a pleasant driving car and something horrible! Even the smallest wear, stiffness, or misalignment can cause an incredable amount of vibration through the car.
Just changing the Universal Joints can put a shaft out of balance - please note that unlike the halfshaft UJs, the ones in the propshaft should not be set tight. The type of propshaft you have fitted determines the cure.
Strap Drive (what I have)
Check for any broken straps and that there is no wear in the pin which fits into the prop end - a worn pin means the prop is scrap as it will not balance on the car even though it may balance on the machine. If all is OK, change UJs and rebalance.
end of quote.
Ok
Now the straps are ok, The question is what pin are they refering to? There is a blue tapered item in the center of the differential flange, that looks like it could help center the flange alignment. Is that the pin they refer to?
Camera's on the blink, right now, sorry.
Thanks
Propshaft Problems
end of quote.
Ok
Thanks
