Joe_Pinehill
I'm in NJ, its been cold for two weeks, (below freezing). I like to start the Spitfire (1978) at least two times a week, even if I dont drive it, to keep the battery up, and fresh gas in the carb.
I tried on Tuesday night. I could tell the battery was weak, it did crank, but did not fire. I checked for a spark, by plugging a sparkplug into one of the cables and grounding it, and it was sparking. It was late, and rather then get frustrated, thought i would try the next day.
Wednesday, I got home, charged the battery for 2 hours, and turned the key and instantly fired to life.
Can the weak battery alone do that? I was wondering if I should unscrew the drain plug in the carb and make sure I dont have water that might have frozen that evening.
Should you semi-routinely drain a carb?
