Hi Guest! If you appreciate British Car Forum and our 25 years of supporting British car enthusiasts with technical and anicdotal information, collected from our thousands of great members, please support us with a low-cost subscription. You can become a supporting member for less than the dues of most car clubs. There are some perks with a member upgrade!
does anyone know the spitfire axle thread size? My first two threads are striped and I need to clean them up with a die, but I need to know what size die I need.
back, there not bad, its the first two threads so the nut dosent go on straight,The nut wont even touch them when it is tightened down, just have to get the nut started straight.
Same thing happened to me on my first Spit - after a little too aggressive attempt to pull the hubs. Guzzul's comment on a thread file is a good one, those tools are very handy to clean up threads. I actually used both thread file and die and it repaired just fine - the damage in my case was beyond the nut once everything was tightened up again.
I would be very hesitant using a die since it is likely to follow the incorrect threading and then you will be in bigger trouble.
The thread file is a better idea.
I bought a tool a few months ago called a "thread mate"
It was cheap enough that I figured it was worth the risk. Surprisingly, it works very well. Easier than a thread file. Don't know if they are available in the US yet. As I recall it was about $15 or so I have gotten my moneys worth!
