malice
Well this morning I went down and removed the trashed top. The frame is in very good shape. Ill cut straight to the chase: when installing the new top, I suppose I will have to remove the rivets from the header and the retainer bar and re rivet the new top, correct? Any advice on this. They don't look like typical rivets, any of you know procedure for this?
Thanks!
Thanks!
