spit71
Hello, I am in the middle of a rear suspension rebuild on my 1971 MKIV Spitfire. It didn't start out as a complete rebuild, but that's another story.
The driver's side rear bearings were so destroyed that the axle had to replaced. No problem, but I was accidently sent the longer one from a "74+. I decided that I might as well just switch to the longer ones on both sides since I would rather have those anyway, right?
I'm embarassed to admit that I was actually surprised to realize that my handbrake cable was no longer long enough.
One new '74+ rear handbrake cable delivered later and I CAN NOT get the old one threaded out of the car. The factory manual and Haynes is of no help.
I have removed all of the little clevis pin brackets and spring retainer tidbits off of the ends. The threaded end on the cable is too long to fit through the frame mounted "bend point" between the yolk and the end. This bend point has "eyelets" that the cable runs through at each end of the curved channel.
Does anyone know a trick to this? I am out of ideas. I try very hard not to lose patience and break something.
I am tempted to cut the cable, but I fear not being able to get the new one in.
