doates
Hello Again,
I have swapped carbs on my 70 Spit MK3 from the Zenith to SU HS2's. Went through the SU's a couple of years ago and installed a rebuild kit. I installed them at that time and got the engine idling pretty well. Then I let it sit for a couple of years with gas in the carbs. So after dis assembly and cleaning I can get it to idle at about 800 but after it gets warmed up it surges from 750 to almost 900 in about 1 second intervals. The plugs show sooty black but when I lift a carb piston it stumbles like it is running lean. When I rev it to 2000 or so the surge seems to disappear.
Because of transmission problems (mentioned elsewhere) I can't tell you what it does at speed/under load.
Any suggestions would be greatly appreciated.
Thanks....Dennis
Thanks....Dennis
