Speedometer removal
Goldie
I need to recalibrate my speedometer for my 1967 BJ8 after changing the rear end to a different gear ratio. What are the steps to remove it from the dash? How does one remove the long stem that resets the odometer? Do I need to disconnect the speedometer cable first from the back or after I pull the unit forward?
Healey Nut
Fairly sure a rear end ratio change will not require speedo recalibration , now if you change tire size etc then that's different . Changing the rear end ratio changes the motor rpm not the distance travelled by the number of wheel rotations . I'm no science major so some of the other whizzes on here can chime in and correct me .
A simple call to Nisonger Instruments and Peter can confirm it .
If if you insist on removal it's a 5 min job disconnect the cable pull the panel light bulb and remove the thumb screws and bracket . You don't need to remove the reset stem for the odometer .
Duane_Rhynard
Goldie,
Anthony Rhodes has put together a nice article on speedometers (Link Below), I hope it helps!
https://obswww.unige.ch/~wildif/cars/docs/Smith-jaeger_speedo_repair.pdf
Fairly sure a rear end ratio change will not require speedo recalibration.
It does. With a taller rearend--e.g. going from a 3.91 to a 3.54--you get approx. 11% more rotations of the rear wheels--and more distance traveled--for the same gearbox/OD output speed (and vice versa). The speedometer can be changed by moving the indicator needle and/or tweaking the watch/return spring (I've never dared mess with that). The odometer and trip meter require a changing of their driven gears. Or, you can get a ratio adapter that goes inline with the cable.
Keoke
Goldie:
Disconnect the speedometer cable first from the back.
Then remove the speedo's retainer bracket and pull the speedo out.
Then I call Nisongner and tell them what i need them to do.
Course now you down there in Virginia and White Post is just around the corner from you.
steveg
Nisonger will confirm that either a tire size change or axle ratio will require re-calibrating the speedometer.
Peter will ask you to count the revs of the speedo cable when you push the car 52'-9.5".
This will handle your current axle/tire setup.
Friends and I have been through this several times.
Patrick67BJ8
i just done this and it's easy. The hard part was paying...I had to have a new expensive thingy installed in my speedo.
John Turney
Let me correct you. The speedometer connects to the tail shaft of the transmission and effectively reads the driveshaft rotational speed, not the wheel rotation.
Healey Nut
Correct that's why I don't think you need to recalibrate as the rotational speed of the transmission doesn't change with the different rear end gear .
John Turney
How do you figure that? For each revolution of the rear wheel with a 3.9 rear end, the transmission output shaft rotates 3.9 times. With a 4.11 rear end, it rotates 4.11 times. That sounds different to me.
RAC68
I totally agree with John but was slower to respond
The speedometer does read the rotations of the transmission tail shaft but, keep in mind that the actual speed of the car is determined by the distance covered per unit of time (miles/hour). In this case, we are changing the rear ration and this change will alter the number of tire revolutions per trans tail shaft revolution. As a result, the 3.54 rear will turn the driving wheels a greater number of revolutions then the original 3.9 rear and result in a lower then actual speedometer reading.
Ray(64BJ8P1)
Duane_Rhynard
The rotational speed of the gearbox does not change but your speed over the ground does! That is why you need to recalibrate the speedometer when you change rear end ratios or tire size. If you have an original parts manual, you will see their are different speedometers for the different rear end ratios.
steveg
I've recalibrated on the following occasions: 3.54 rear end; Toyota .85OD trans & 185-70 tires; Toyota .78 OD Supra trans & 185-70 tires; conversion to 180-85 tires - each time the speed of the car relative to the revs of the transmission tailshaft changed. The speedo is basically a tach that measures engine revs over distances which can vary according to axle ratios and tire size.
That's why it's important to measure over the 52+ ft per above as Nisonger and the other outfits recommend.
If you have a Garmin, you can verify these changes.
... but the distance you move forward increases approx. 11% for the same rotational speed of the gearbox--going from a 3.91 to a 3.54--hence the speedometer will indicate 11% low. When I put a 3.54 in my BJ8, I had the speedo recalibrated--by Klaus at Palo Alto speedo--and he put the new gears in for the odometer and tripmeter, but neglected to recal the speedo itself. A friendly CHP informed me of the ommission.
Put another way, it takes 3.91 rotations with the stock rearend to move the rear wheels one circumference--approx. 82" with a 26" dia. tire--but only 3.54 rotations with the taller rearend, so your speedometer 'thinks' you're going slower down the road than you are.
Keoke
Well just get a tire size calculator on the web N see how much your speedo error is for different size tyres when compared to originals-:highly_amused:
bob hughes
Nice one Keoke,
I just use the local speed recorder mounted on a lamp post, not connected up to any recording device, just advises you of your speed :angel:- check it against your speedo and that's it Q.E.D.
:cheers:
Swoz
Changing the rear end ratio will effect the speedometer reading and require recalibration. The speedometer is calibrated for a specific rear axle ratio such that a specific number of turns on the driveshaft will result in a specific speed based on the speed of the rear wheel. By changing the differential ratio the tire speed (rpm) will change in relations to driveshaft speed (rpm). Said in more understandable way, the distance covered by the vehicle in in the same amount of time will be less or more based on the ratio change as Bob mentioned above. Since speed is a measure of distance per unit of time, whenever you change the time required to cover a distance or the distance itself the actual speed is altered. In addition, it should be noted that calibrating the needle to tweak it to the proper speed is able to be done when the speedometer gears are correct for the ratio of the differential. You will notice that the speedometer has numbers on the face, which indicate the differential ratio it will work correctly for. Without having that correct the odometer reading will also be inaccurate. The miles registered under the different ratio will be less or more based on which way the differential ratio was changed. As indicated by others in the above posts, there are some good websites on this. Nisonger in Mamaroneck can answer what needs to be changed to correct for the change in differential ratio. I hope I didn't confuse the issue.
J TR2/3/3A Speedometer Works Removal Triumph 10
S Help - Speedometer Removal Triumph 10
jjbunn Speedometer removal MG 17
M TR2/3/3A HVDA Speedometer Drive Triumph 10
GeorgetheTR3 TR2/3/3A Speedometer Triumph 4
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
roscoe GPS Speedometer Austin Healey 6
J 1985 TVR 280i Speedometer Cable TVR 4
F TR4/4A Speedometer cable replacement access Triumph 0
DocDup1 MGB SpeedBox Speedometer Drive MG 0
R TR2/3/3A Speedometer Reset Triumph 26
BritBite Speedometer Right Angle Drive Austin Healey 5
roscoe GPS Speedometer Austin Healey 10
PAUL161 T-Series TD/TF speedometer gears. MG 3
AUSMHLY Speedometer Fluctuation Austin Healey 21
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
M TR6 Speedometer Triumph 2
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
P TR6 Jumpy Speedometer cable Triumph 4
PAUL161 T-Series Interesting Speedometer Scenario MG 5
John Turney Getting Speedometer out of the Case Austin Healey 6
K TR2/3/3A Speedometer needle bounce? Triumph 1
P Speedometer confusion Spridgets 1
J TR2/3/3A Speedometer Bounce with Odometer Gear Movement - Benchtop Calibration Triumph 3
RJS TR4/4A Speedometer and Angle Drive Triumph 6
T Speedometer Repair Problem Austin Healey 5
R TR2/3/3A Speedometer Routing Triumph 15
KVH General Tech Speedometer Not Working Triumph 5
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
K TR2/3/3A Speedometer Error Again Triumph 8
G Spitfire gps speedometer Triumph 6
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
S Speedometer Angle Drive Austin Healey 2
T Wanted WTB 100 / 4 Speedometer Austin Healey Classifieds 0
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
F How does overdrive Annulus effect speedometer Austin Healey 10
M TR4/4A Speedometer Cable Routing Triumph 7
2 TR2/3/3A Can't get zero on speedometer 60K tr3A Triumph 6
B Speedometer Cable Routing Austin Healey 9
UmmYeahOk GT6 What do I need for a speedometer fix? Triumph 16
Michael Oritt Speedometer drive issue Austin Healey 4
R TR4/4A Speedometer off 10mph Triumph 6
R BN7 Speedometer issues Austin Healey 1
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
1 MGB Speedometer and tachometer on '66 MGB are not working MG 8
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
T TR2/3/3A Instructions for cleaning & re-lubricating speedometer? Triumph 5
