Hi Karl there is an inner main spring that is very sensitive. If you can get the needle to bounce when you gentle flick your wrist, is a good way to tell at a swap met if the gauge is functional.
Your needle could have fallen off the shaft because they are a push on fit.
Steve
Likely muck accumulated over the years. Google a document written by TR owner Anthony Rhodes on Smiths Speedometer repair. He goes into detail on how to service and repair these speedometers and odometers. It is the best doc out there for this task. It is free, lots of clubs reference it.Does anyone know why the speedometer needle would fail to return to zero and hang up at 8 mph?
Karl, this may not be your issue, but that problem can be caused by incorrect adjustment of the axial float screw holding the cupped wheel. If you remove the speedometer assembly and take the needle and faceplate off, there is a small screw immediately next to where the cupped wheel shaft protrudes (see attached photo). That screw adjusts the end float of the cupped wheel and shaft it rides on; the bearing setup is similar to jewel bearings used in watches and old instruments (like the speedometer). Too much end float (screw is turned out too much) and the cupped wheel will rub against the baseplate (holding the odometers), and too little end float (screw is turned in too much) and there will be too much friction against the shaft (which is shouldered near the top just under where it protrudes). Either way, friction will be a problem (that instrument has no room for friction). That ended up being the problem with a speedometer that I rebuilt; correct adjustment of the screw fixed the problem.Does anyone know why the speedometer needle would fail to return to zero and hang up at 8 mph?
