dklawson
Just for the record, the "flywheel thing" is a magnetic coupling to the aluminum drag cup. The drag cup is supported on a needle bearing and according to Anthony Rhodes, the needle bearing should not be lubed at all.
You can get a copy of the PDF from Mr. Rhodes web site:
https://home.comcast.net/~rhodes/speedo.html
or faster download at
https://pcbunn.cacr.caltech.edu/jjb/TR6/speedo.pdf
