Speedometer Issue
asoupley
Finally got a cable for my speedometer... thing is, once it won't go past 30mph even though I am going faster!
Any ideas?
Thanks
Tony
Broke? Try it with a varable speed drill on the end.
Check the "pinion" gear inside the transmission too. I bought and replaced my cable (used jack's drill trick) and it still didn't work. There is a screw that holds a little forked bracket on the transmission that hold the pinion gear. Easy to replace and works great!!!
Try looking at this. Helped get the "new unit" functioning
mywebpages.comcast.net/rhodes/speedo.pdf
I had a broken speedometer pinion gear in a Rustang that had this same problem.
