TR2/3/3A Speedometer cable fastener locations
Chuck Murphy
I am installing the speedometer cable on my 1957 TR3 left-hand drive with Overdrive. I am confused as to where this long speedometer cable is fastened to the car body. I have the clip located by the battery box. Are there any more clips/fasteners? Any on the valence? The parts book does list two more clips - one to cruciform and one to frame (the clips appear to be of the type used to hold the brake line to the frame). I can not see where any such clips would fit (unless I have used a frame hole for a brake line clip and it is really for the speedo cable???). Chuck
sp53
I am not sure on an OD cable, but I remember thinking the same thing once, and it turned out that I had put the brake line there and the connector was a brake line clip. I remember thinking also that the clip might pinch the cable. Next time I am under the car I will see what I did. I just cannot remember.
C
Chuck Murphy
Thanks for the info. Also read the earlier posts on this topic. But I am still confused. (1) I am not sure which clip on the frame should get the brake line and which clip should get the speedo cable. There is a clip a few inches to the rear of the rubber grommet that the brake line and speedo cable go thru on the frame. Is that the clip that is for the speedo cable? It would tend to pull the speedo cable forward so it does not interfer with the jackng hole. (2) I am more concerned that the speedo cable in the egine compartment is so flopy - does it go on the engine or fender side on the choke cable?? I do have the cable clip at the battery box. I don't know why I am finding this so confusing! Chuck
CJD
Hope these help. This one shows my rusty old cable running up and accross the front top edge of the firewall. Two clips shown. It's the larger of the many wires/cables in the picture.
And here it is going into the upper firewall.
In answer to your question, it routes well inboard of the choke cable and brake line.
TR4nut
John-
I'm glad you posted that - first time I've seen a picture of a clip on the lower side of the firewall.
Randy
C
Chuck Murphy
I have never seen that clip on the lower side on the firewall before either - and it does solve my problem of a floppy speedo cable in the engine compartment. Thanks for the photo John!
Chuck
charleyf
Thanks also for the picture. I am restoring a 3A that I did not take apart. Seeing the location of the electrical parts , clips and what was used for rubber plugs on the dash if extremely helpful.
Charley
charleyf
Thanks, I noticed the wiper motor on the " wrong" side. I was looking at the electrics and their positioning. My last TR3 was a 3B. So it had the later fuse box and Lucar connectors. I notice that the flasher unit has the connectors converted to Lucar ends. I am guessing that the location of that flasher unit could be elsewhere but still close.
Charley
CJD
Charley, these will help more with the TR3A. If you need any more angles, just let me know, as there are many more pics where this one came from!
charleyf
John,
Thank you for the pictures, your car has the Lucar or spade connectors. I am working on a car with bare wire ends and the old style fuse box. What I am looking for is the proper location and orientation of the voltage regulator, fuse box and solenoid. I noticed on the TR2 in the previous picture that the direction of the voltage regulator and fuse box was different than on your car ( which was the same as my 3B). I am thinking that the wire harness change came at TS60000.
Charley
charleyf
Don,
Excellent view and clarity, I can see the color of all of the wires and everything that I wanted to see. It looks like the TR2 and early TR3 were the same in this regard.
Thank you very much for the help.
Charley
J 1985 TVR 280i Speedometer Cable TVR 4
F TR4/4A Speedometer cable replacement access Triumph 0
P TR6 Jumpy Speedometer cable Triumph 4
M TR4/4A Speedometer Cable Routing Triumph 7
B Speedometer Cable Routing Austin Healey 9
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
S BJ8 Speedometer Cable Austin Healey 6
S Speedometer Cable Spridgets 5
P TR6 speedometer cable Triumph 21
R TR2/3/3A TR 3A Speedometer Cable Route Triumph 12
C routing of speedometer cable on BN6? Austin Healey 11
KVH TR4/4A Long Speedometer Cable for OD Transmission Triumph 10
J TR2/3/3A Speedometer cable routing and dash switch layout. Triumph 2
Scotsman TR2/3/3A HVDA transmission conversion. 90* speedometer cable adapter may be required on TR3's Triumph 4
P Mysteries under the BJ8 transmission tunnel, speedometer cable, overdrive and gerabox Austin Healey 1
K TR2/3/3A Speedometer cable fittings? Triumph 4
B TR6 Brand New Speedometer Cable breaks Triumph 5
Patrick67BJ8 Speedometer Cable-5-speed Trans Austin Healey 6
R Smitty Speedometer Cable Fix Austin Healey 1
O TR2/3/3A TR3 Speedometer Cable length? Triumph 5
G TR4/4A tr4a speedometer cable Triumph 9
angelfj1 Speedometer [cable failure] and repair Triumph 5
J TR4/4A TR4 Speedometer cable routing Triumph 0
longbridgehealey Speedometer cable not spinning Austin Healey 15
T Quesiton on A-type OD speedometer cable fitting Triumph 12
D speedometer cable Austin Healey 17
T TR4/4A TR4 Speedometer Cable Triumph 3
bcbug Another speedometer cable replacement question Spridgets 4
bighealeysource T-Series Stuck speedometer cable on TC MG 3
J Speedometer cable issues? Austin Healey 7
V TR2/3/3A TR-3B Speedometer Cable Triumph 6
gubba speedometer cable right angle adaptor Triumph 4
TimK Speedometer Cable Routing - BN7 Austin Healey 2
JPSmit speedometer cable question Spridgets 8
Sarastro Source of a good speedometer cable? Spridgets 5
S Speedometer Cable Installation Problem Austin Healey 5
Magyar Speedometer and cable Spridgets 5
S Lubricating Speedometer Cable Austin Healey 13
T Speedometer cable Triumph 0
2wrench TR6 '74 TR6 Route of speedometer cable from overdrive. Triumph 7
walshja speedometer cable Spridgets 9
S TR2/3/3A Speedometer cable tr3 Triumph 3
C speedometer cable issue MG 2
T Speedometer and cable Triumph 2
W speedometer cable and housing MG 7
HEALEYJAG 100 speedometer cable routing Austin Healey 5
I TR6 TR6 speedometer cable Triumph 3
Rob_P Speedometer Cable MG 7
AUSMHLY Speedometer cable length Austin Healey 4
T Broken Speedometer Cable Triumph 5
