Rob Glasgow
The speedo on my BT7 quit last week. On pulling the angle drive on the overdrive, I found the short cable that inserts into the pinon bearing was broken. I was not supprised since the same thing happened 15 years ago. I think this must be a common failure since I see a lot of angle drives for sale on ebay.
The problem is I can't remove the broken piece of cable that is lodged in the pinon bearing. It's jammed inside and there isn't enough protruding to pull it out.
Any suggestion on how to remove it without damaging the internal square shoulders?
