Speedo Bounces Until It Hits 30 or 35 MPH
78MGB
Greetings,
Relaxing in the MGB today and noticed the speedo bouncing until we got up to 30 or 30 MPH. Do I need to lube the cable? If so, can I pull it from the speedo instead of the tranny?
Thanks!!
Yes you can, and lubing the cable may fix the problem.
Sometimes a new inner cable is required.
All the best, Ross.
The cable only pulls out from one end. I believe Repro is right, it's at the speedo end. Definatly try that first. slean the cable with some WD40 and apply a light coating of oil or white lithium grease. That should clear it right up.
