Speedhut Gauges
Jim_Gruber
Thinking about issues with Speedo drive on a 5 speed and needing to make an access hole so adapter will fit in there as well as converting from Mechanical Tach to Electronic Tach as I want to run an alternator. These are costs to consider and I seem to recall someone installing a Speedhut GPS Speedo and matching tach in their BE. Gundy?? I can't recall now.
Can you post pics of these gauges in your BE? I seem to recall custom graphics being available or something like that to turn these into Smith Gauges. Looking for details. TIA.
You do not need to cut a hole for the speedo adapter on a 5-speed.
Here's an older thread about using the electronic transmission sender for the Speedhut electric tach. I didn't use (or have!) the Rivergate angle drive, but this set up is working well. Click on "Blue Max's" thumbnail picture-- it looks like he got Speedhut to nail the look of the original Smiths' gauges. Maybe you could email them that picture to show what you want.
https://www.britishcarforum.com/bcf...dhut-Electric-Speedometer!&highlight=speedhut
Just be sure to check-fit the gauge retaining ring, making sure it screws down ALL THE WAY CLEANLY (I had to clean up the threads with a razor blade, sandpaper and a plastic scrubbing pad) BEFORE you install it in the dash!
They make a GPS speedo so you don't need a sending unit at all.... even works with Positive Ground, they informed me when I asked about a year ago...
Here's the ones I had them make for me, they turned out really well, sorry for the sorta blurry unfinished pics, I wasn't concerned with originality but I was concerned that the speed cable in the 200-4r comes through the tunnel around my thigh and goes under the driver seat up to the speedo. I was happy to patch the hole and be done with it.
How much extra do they charge when you supply custom artwork?
Also, my design that I originally sent them was too detailed so they found another one and did all of the editing for me. They didn't charge any more than the initial 10 dollars and I even got a multi gauge discount for buying the 2 gauges together. I'm very happy so far with my speedhut experience.
I was modifying the dash anyways so the high beam light and turn signals in the speedo mean I can fill those holes in the dash.
Alan had some custom GPS gauges made. He added some indicator functions too. I think he is going to route some line behind the mirror. Very neat. The faces look like a retro version of
original ones. I like them a LOT.
Sigh....next time.
I had a working Smith's speedo from something. Not sure what. Works and is pretty spot on. I went with this for the Smith's tach.
"What do you want and we will make it". This is what I wanted.
Those guys will make you anything.
Speedhut must be the same way.
Good for us.
Alan is a bad influence. Those stock looking Speedhut jobs are the bee's knees.
:cool-new:
