Spedo shaft direction
DavidApp
Anyone know which direction the speedometer drive should turn? I have a couple of speedometers and want to test them to see if either work.
David
BobHaskell
David, I don't. But when you drive in reverse the cable spins the other way without ill effects. So just spin it slowly in both directions to determine the normal direction.
it spins in the direction the needle turns ... that is how the magnet applies force to the clock spring.
Joe Schlosser Spedo reading low Spridgets 8
Joe Schlosser Bugeye Spedo jumping Spridgets 6
5 Checking The Spedo Spridgets 11
C BJ8 spedo cable routing Austin Healey 2
R Spedo cable Austin Healey 5
Dougal How to dismantle a spedo with trip adjuster rod Austin Healey 6
ekamm TR2/3/3A TR3a spedo drive Triumph 19
ekamm TR2/3/3A TR3a Spedo question Triumph 10
G Spedo issue Triumph 5
PAUL161 Doc, Spedo. cable MG 1
R Spedo bezel MG 28
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
RJS TR4/4A Drive Shaft - Prop Shaft Alignment and Balancing Triumph 8
WHT Rocker Arm Shaft Replacement Austin Healey 21
D XK150 Transmission Input Shaft Jaguar 1
AUSMHLY 1st Motion Shaft Bearing Austin Healey 7
Rut MGB 62-67 upper MGB steering shaft MG 3
G Installing New Rocker Shaft Assembly Austin Healey 3
Michael Oritt Propeller Shaft Hardware Austin Healey 6
OZ_BN1 Drive Shaft Universal Joints Austin Healey 2
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
T MG Midget 1500 crank shaft pulley Spridgets 0
Popeye TR4/4A Accelerator shaft install - location of bushing plates? Triumph 2
AUSMHLY Bad 1st Motion Shaft or Mainshaft Symptoms Austin Healey 13
AUSMHLY 1st Motion Shaft Play Austin Healey 3
R TR6 Drive shaft orientation Triumph 3
S TR2/3/3A Replacing the cam shaft Triumph 27
W BN1 Gearbox First Motion Shaft Austin Healey 0
S Removing Overdrive Shaft Lever Pin Austin Healey 7
J RIB CASE MAIN SHAFT ASSEMBLY Spridgets 2
K TR2/3/3A Sending out SU's for throttle shaft rebushing........ Triumph 4
P Wanted BN1 can shaft Austin Healey Classifieds 0
S Axle Shaft Installation Difficulty - Help Sought Spridgets 8
C Bugeye propeller/drive shaft- universal joint Spridgets 1
Walter74 Kent AH4 cam shaft Austin Healey 18
71TR6 TR2/3/3A TR3A Drive shaft cork seal Triumph 10
L TR2/3/3A Drive shaft question Triumph 5
Got_All_4 TR6 Differential ID year & output shaft removal Triumph 11
M MGB First Motion Shaft MG 5
J General TR Cam shaft upgrade????? Triumph 3
J Wanted Front Yoke on Drive shaft Spridgets Classified 2
J TR2/3/3A Triumph TR3 cam shaft measurement Triumph 2
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
T Windscreen wiper wheelbox rubber shaft seal Austin Healey 4
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
R Center Gearbox Input shaft bearing Austin Healey 9
B TR4/4A Transmission Input Shaft Clearance Problem Triumph 16
