Spark Plugs with Crane Ignition
LLAngus
What is the proper plug gap to use on a Crane Ignition? I am using NGK BP6ES. /ubbthreads/images/graemlins/driving.gif
Thanks, I'll give that a try. I just thought 25 thousands was a little close for the Crane ignition setup.
/ubbthreads/images/graemlins/yesnod.gif
Sure is Bruce. You might as well take advantage of the extra ignition. You may want to try advancing the timing just a nudge.
Jeff
I can't believe it!! With the redone head and new plugs the acceleration is great and smooth. I need to adjust the valves again. I tend to set them a little loose until the motor is running. WOW took a trip down the road and back, I just can't believe the difference in the GT.
Bruce L
/ubbthreads/images/graemlins/lol.gif /ubbthreads/images/graemlins/lol.gif /ubbthreads/images/graemlins/driving.gif /ubbthreads/images/graemlins/lol.gif /ubbthreads/images/graemlins/lol.gif
[ QUOTE ]
Bruce, I run the same plug and setup on a 1275 Midget, with the plugs gapped at .035". Works just fine.
Jeff
[/ QUOTE ]
Jeff would you suggest the same for a 1500/crane?
mark
Mark,
I would if he doesn't. I'm running a 1800/Crane. It fires beautifully.
/ubbthreads/images/graemlins/hammer.gif Bruce L
ok thank , duly noted, or should i say evernoted
mark
Crane 3000. ".035".
What is the ohm rating for spark plug wires? Anyone know? I have a low power miss, now. /ubbthreads/images/graemlins/crazyeyes.gif
LLangus;
Zero OHMS on a one-to-ten Ohms scale for spark plug "wire". 10,000 OHMS Max for the string stuff---Keoke /ubbthreads/images/graemlins/hammer.gif
