AUSMHLY
64BJ8. Negative ground. Pertronix Ignitor Electronic Ignition. Lucas sports coil. Tachometer was sent to Nisonger two weeks ago.
After installing my mechanic says the tachometer does not read correctly. Example, the tach reads 3000 rmp, his equipment says it should be reading 3500.
Nisonger confirmed the tachometer is correct and recommends I replace the stranded copper spark plug wire to suppression wires. Mechanic says performance may not be as good if I replace the copper to suppression.
The car does run great and I have my mechanic to thank for that.
I'd like the tachometer to read correctly and I'm wondering if this situation is caused by using copper spark plug wires, or if replacing them with suppression will solve the problem of the misreading tachometer, and not affect performance.
Anyone using the same set up as me and having the same misreading tachometer?
Anyone using the Pertronix 7mm suppression spark plug wires in this set up, or another brand of wires? If so, does your tachometer read correctly?
Cheers,
Roger
Cheers,
Roger
