dklawson
I'm not sure which forum is best to post this in so I'll start here.
This is not thetypical “what spark plug is best for my car” question. This is a“have you ever measured” question. It is not specific for anymake or model of car. It is something that is bothering me.
I have a car that isgiving me some running problems so I cleaned the old spark plugs andthen decided to measure the resistance of all the high tensionignition parts. The resistor plug wires measured 500 to 1000 Ohmsdepending on length. The dizzy cap measured fine with no shortsbetween terminals. Then there were the spark plugs.
These are standardplugs (not resistor plugs) so I expected to measure Zero (0) Ohmsbetween the plug’s terminal and the center tip at the firing end. I only found Zero resistance on about 3 out of 10 plugs. (Once Istarted making measurements I brought out ALL my old spark plugs tomeasure). Apart from the handful of plugs that measured lowresistance, MOST of my used plugs measured several hundred thousandOhms or more.
All these plugs werepresumed working when removed. I have never had an engine startmisfiring due to a failed plug so apparently the resistance Imeasured does not affect the firing of these plugs… much.
So have you evermeasured the resistance of new and old spark plugs? Have you everseen a published value that says “if the resistance is above Xdon’t reuse the plug.”? Please share your thoughts andexperiences.
Thanks,
Doug L.
Thanks,
Doug L.
