TR6 Source for Elevator Bolts?
ichthos
Hi All. I need a source for a couple elevator bolts. They look to be 3/16" fine by 3/4" long. They hold my license plate light bracket on the rear bumper. Any suggestions are appreciated.
Kevin
dklawson
I have only seen elevator bolts available from McMaster-Carr (www.mcmaster.com) However, the smallest I saw when checking their website tonight was 1/4-20. That 3/16 you are looking for will be either 10-24 or 10-32. If I see/find anyone carrying them I'll post back.
Elevator bolts are usually used in places where you need to spread the load out over a large area and have minimal space for tall fastener heads. I am sure you can improvise with something. Since I am not familiar with your application I cannot make many suggestions.
Have you considered taking a Tee-Nut and Loctiting a #10 stud into it? That would be very similar to an elevator bolt.
Tee-Nut page at McMaster: https://www.mcmaster.com/tee-nuts
I
ichthos
I was wondering if it were the 10/32 too. I went to Rimmer Bros, and they listed the nuts as 3/16" fine. Is this the same thing as 10/32?
ed_h
Carriage bolts are pretty close, and McMaster carries 10-32 and 10-24.
Ed
TR3driver
Great Pumpkin - R.I.P
Any chance they meant 3/16 British Standard Fine? Very similar to 10-32, just .0025" smaller diameter. And 55 degree threads instead of 60.
I
ichthos
The nuts are listed at Rimmer Bros. as 3/16 unf. Kind of suprised the big four carry the nuts but not the bolts. The bolts hang down through the bumper and get rusted. If I can't find the correct elevator bolts, I will try using the carriage bolts. Worst case scenario is I could grind the heads flat. Still hoping to find the correct bolts. I will keep McMasters in mind though-thanks.
Geo Hahn
FWIW - my local Ace Hardware carries elevator bolts though whether they have them that small I cannot say.
My machine shop consists of an angle grinder, drill press and bench grinder - I'd be looking to make something that would do the job.
dklawson
I don't know the details of the TR6 license plate light. However, if an elevator bolt or carriage bolt is appropriate for this application, it is unlikely that the thread type or pitch is important. Regardless of the original pitch, you will need the correct new nuts to go with your new fastener.
TR3driver
Gliderman8
Could it be an 8/36?
FlyingCat
It may not be what you have in mind, but Ace Hardware (at least, the one down from my house) carries elevator bolts.
DNK
But come to think of it
Isn't the screw part of the base and not separable
dklawson
Measurements with a set of calipers and a couple of pictures would help.
Tybalt
Give that man a cigar! From a fastener size standpoint 10-32 is a nominal 3/16" fine thread. The min and max diameter for the grip area is .186" to .189" for AN3 sized fasteners and threaded to a MIL-STD that covers the entire range of unified threads. I'm not seeing what you want in an elevator bolt but am seeing it in an austenitic CRES carriage bolt from Bolt Depot.
https://www.boltdepot.com/Carriage_bolts_Stainless_steel_18-8_10_(3_16)-32.aspx
I
ichthos
The bolt can be removed - I removed one. I will borrow my wife's phone when she gets home and try posting a pic. I think I will take a trip to the hardware to try and fit one of the original nuts on to a 10-32 bolt.
R TR6 Help: Brake Part Source or …. ? Triumph 1
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
Jayplum TR2/3/3A Source for quality parts Triumph 11
B Vacuum Source Austin Healey 4
W Best source for Bugeye front shocks Spridgets 3
B TR6 Source for Carmine Red Triumph 4
steveg TR6 Source for fuel line P-clip Triumph 17
Sarastro TR4/4A Source for good convertible-top snaps Triumph 6
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Michael Oritt Tenax fastener source needed Austin Healey 6
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
R TR6 Body Parts Source, Upper Midwest Triumph 6
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
S TR2/3/3A source for those little drain hoses Triumph 6
I TR6 Source for license plate light bracket? Triumph 5
steveg Excellent source for info on and rebushing of SU carbs Restoration & Tools 0
MikeAH100M Whitworth Source Austin Healey 8
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
K Healey Blue Paint Source Austin Healey 30
D Body work finishing supplies source. Restoration & Tools 0
Csarneson Source for Distributor Fiber Thrust Washer Austin Healey 3
JPSmit DC Power source thoughts Restoration & Tools 11
B TR2/3/3A Locating source of oil leak Triumph 6
J Half round tube or D tube source ?? Restoration & Tools 2
HealeyDave TR2/3/3A TR3 Dash Cover Source Triumph 9
B New frame candidate or parts source? Austin Healey 12
S Bay Area source for 60 Sprite Roll Bar? Spridgets 6
Jim_Gruber Source for PosiDrive Screws Spridgets 7
R TR2/3/3A Source for rubber seal on A/M side curtains Triumph 4
J TR4/4A TR4A rear wheel cylinder source Triumph 3
I Bigeye transmission source? Spridgets 7
Rut TR4/4A Good interior source Triumph 29
R Source for return spring on Early BN4 locking door handle? Austin Healey 1
Jim_Gruber Source for Small U Bolts on 1/4 Elliptic Springs- Spridgets 11
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
Csarneson Source for BN4 2nd Gear Austin Healey 8
CJD TR2/3/3A Source for Horsehair Padding? Triumph 10
Michael Oritt Rear upright casting--source needed Racing 4
I TR6 Under bonnet sticker source Triumph 3
D General TR Front carpet source? Triumph 1
Steve P. Best source for new tappets? Austin Healey 11
I General TR Source for glass mirrors Triumph 5
Patrick67BJ8 "Cover" for Top. Source wanted Austin Healey 6
O TVR 2500m weatherstrip source needed TVR 2
