tr6nitjulius
Recently having to disconnect & drain, remove radiator, cross member, to get at timing chain seal once parts were back together noticed a difference in how electric fan worked & amp gauge 1/4 strong on the C+ side occasionally jumpy while driving vs hanging dead center no movement, new battery 12.93 vdc
Prior: Fan would come on after engine decided it was hot enough whether at traffic light, or sitting in slow traffic dropping rpm near 800 rpm as soon as moving fan would turn off rpm back to 850 rpm at next stop before fan kicked on. Return home from 4 hr drive fan auto on as pulling into garage once parked ignition off, fan off
After: Engine hot noticed when stopped ignition off fan would turn on, shortly would turn off different than my muscle memory
Simple fix wired to wrong spade in fuse box
correction made good2go
