Jer
About 2 weeks ago when I was leaving work at the end of the day Midge smoked (oil smoke - not antifreeze smoke) when I started her up, then no smoke for rest of the drive... thought maybe it was a valve seal leaking... then I park for the night, start the next day - no smoke, which contradics valve seal as they are usually consistant with smoking after every shutdown/startup cycle... then while driving and stopped at stop light, it starts smoking, then drive away & it clears up... yesterday when I start to go for lunch, smoke, go to leave at end of day... no smoke...
Any ideas what the issue may be ? I'm starting to wonder about the pancake PCV valve... it is one item that could be failing sporadic causing these "random smokings" as I believe valve seals/worn rings would be more consistant ? 1275 Motor was rebuilt about 6 years ago & has approx 10,000 miles on it now.
Hi Guest!
