Likely due to its limited audience. The self-timer lever doubled as a "metering lock" when pushed inboard, I found it a frustration to have to hold it in place at times. Came up with this widget to do the job:
Just had to touch it on the "outboard" side of the lever and it released.
Best tool for me was that combination. 35~70 ∱3.5 and the FE with a motor drive. Just did an "equipment check" to find the inner contacts of the MD-11 corroded. A chopstick with some green Scotch-Brite fixed that.
