Got_All_4
While completing my radio installation something happened and the wires shorted out and burnt all the way to the kill switch. This isn't the reason I'm writing. After putting everything out and pushing the car out of the garage I dried everything out started the car and tried to back up to my other garage where I'm closer to everything. As I was backing up the car it was acting like the E brake was on but it wasn't. Parked the car in 3rd gear and continued to work on the car.
There is a slight grade there and as I was working the car broke loose and started down the grade in third gear with the clutch out! Jumped in and tried it in every gear and it was like the clutch was not engaged. Decided to start the car and see if it would pull forward and it did and felt proper. Tried reverse again and the same sensation. I noticed that the overdrive switch was on and I turned it off. Backing up was a lot better. Still didn't feel 100% correct. Put the overdrive switch back to the on position and getting that same sensation. What can be going on here?
