Webb
Hey, changed out the points for the first time on my TR6 just a minute ago, and something's up. New points, condenser, low tension lead and block, and whatever that tiny wire that runs from below the points plate to the case of the distributor is called. You can see it as the shiny copper wire in the picture. Anyway, it will turn over but won't start. I checked compression on all cylinders right before I did this, so it's slightly possible that it's flooded, but I doubt it. What have I got hooked up wrong? Note that the condenser eyelet and low tension block eyelet ARE touching on the post. I was pretty sure that's how they came off, but couldn't remember for certain. I do have the point gap set correctly, and the points are coming apart as the distrib. shaft spins.
