Someone have new floorpans not installed yet???
fordtrucks4ever
If you happen to have one or the other side, could you measure the exact length. I would really appreciate it.
I am finally getting close to forming new pans and need to make sure of some measurements before preceeding. I would hate to be 1/4" off and then fudge everything to fit. There is enough new sheetmetal going to be replaced, that if one panel is wrong might cause a snowball effect.
Terry, I've got a set but won't be able to get to them to measure until after work tonight. I'll let you know after about 6pm EST, if you still need the measurements then.
Jeff
Measured a new yet to be installed set for a BE. 52" long. 18 5/8' wide at footwell. 22" wide at rear. The panel widens from 18 5/8" to 22" 15 3/8" back from the front of the footwell. Hope this helps.
Thats great. My donor parts are so far off from side to side, I needed a baseline to go with. You guys are becomming partly responsible for the work getting done...on "MY" car. Thanks
