Before I toss the soldering gun, batteries, and everything else in reach out the door ...
How the heck do you connect "tabbed" ni-cad batteries?
The tabs on these sub-c cells are flat, about 3/4" long and 1/4" wide; one on positive end, one on negative.
I can't figure out how to solder those two flat surfaces together. The batteries will go side by side forming a half circle, so the tabs would seem to need to overlap. Something like this:
I've scuffed the tabs with sandpaper, and can get solder to adhere to one side, but can't melt solder *between* the two tabs to join them.
I know you have to be careful about overheating nicads. Any suggestions on how to solder those tabs (negative to positive, etc.) together?
Thanks.
Tom
Thanks.
Tom
